Hallo SchienenDampfer!
Wie es Christian auch schon erwähnt hat, früher ich hatte ziemlich viel mit Charles Dockstader Programms, Valve-Gear gespielt!
Das Programm kann man von hier Downloaden:
Das Programm unterstützt die folgende Steuerungen: (Sorry) :G
Windows Types of Valve Gear Supported
Start Menu, Instructions, Icon, etc File 10
Zeuner Diagram. File 10
Walschaert Inside Admission File 10A
Walschaert Outside Admission File 10A
Stephenson Inside Admission File 10A
Stephenson Outside Admission File 10A
SlipEcc with and without Rocker Outside Admission File 10A
Baker Inside Admission File 10B
Baker Outside Admission File 10B
Southern Outside Admission File 10B
Joy1 Outside Admission File 10B
Hackworth Outside Admission File 10C
Marshall/Hackworth2 Outside Admission File 10C
Bremme/Klug Outside Admission File 10C
Woolf Outside Admission File 10C
Allan Outside Admission File 10D
Gooch Outside Admission File 10D
Young Inside Admission File 10D
Crampton Outside Admission File 10D
Corliss Reynolds Trip Rotary Valve File 10E
Corliss Inglis Spencer Trip Rotary Valve File 10E
Simple Oscillator Oscillating Cylinder File 10E
Franklin Oscillating Cam, Poppet Valve File 10E
Caprotti Rotating Cams, Poppet Valve File 10F
"R-C' Rotating Cam Rotating Cams, Poppet Valve File 10F
Single Acting Rotary Valve File 10F
A J Stevens 1885 Outside Admission double valve File 10F
Southern Inside Admission File 10G
Bagnall Outside Admission File 10G
Baguley Outside Admission File 10G
Baguley Modified Outside Admission File 10G
Blackstaffe Outside Admission File 10G
Milling Inside Admission File 10G
Greenly Outside Admission File 10H
Heywood Outside Admission File 10H
Joy1 Inside Admission File 10H
Stephenson Special Outside Admission File 10H
Double Acting Rotary Valve File 10I
Fink Outside Admission File 10I
Dake Square Piston File 10I
Western River Steam Boat Poppet Valve Calif. CutOff File 10I
Helmholtz Outside Admission File 10J
El Gobernador(A.J.Stevens1882) Outside Admission double valve File 10J
Golsdorf Outside Admission File 10J
Kitson Outside Admission File 10J
Walschaert GWR 4 Cyl Inside Admission File 10J
Hawthorn Outside Admission File 10J
Gresley 3 Cylinder Inside Admission File 10K
Bulleid 3 Cylinder Outside Admission File 10K
Southern Variable Lead Inside Admission File 10K
Hagans Swivel Frame File 10K
Lentz 4 Cylinder Compound Poppet Valve File 10K
Stephenson British Outside Admission File 10K
Aspinal Outside Admission File 10L
Skinner Uniflow 2 Cyl Poppet Valve File 10L
J M G Outside Admission File 10L
Crellin Outside Admission File 10L
Stephenson GWR Inside Admission File 10L
Stephenson GWR Outside Admission File 10L
Sissons Outside Admission File 10M
Twining Inside Admission File 10M
Joy2 Outside Admission File 10M
Klose Articulated Outside Admission File 10M
Bremme Inside Admission File 10M
Walschaert Special Ecc Drive Inside Admission File 10M
Joy1 Straight Link Outside Admission File 10M
Jetzt möchte ich die Steuerung für HF 110 ändern, und dazu sollte ich die Maße kontrollieren.
Aber seit letztem Mal, als ich mit VG gespielt habe, habe ich fast alles vergessen, wie ich es machen soll!
Ich habe für mich – wegen Sprachproblemen – eine kleine Lehre gezeichnet, um die Maße ins Programm einfacher einzutippen.
Ich werde hier über mein Spielzeug berichten. Ich hoffe es ist nicht überflüssig!
