Hallo Zoltan,
ich habe oben den Link auf die vom Modul unterstützten Protokolle eingestellt:
https://github.com/pascallange…nts-listed-alphabetically
Wenn man dort auf Hitec klickt, steht da:
ZitatAlles anzeigenHITEC - 39
Models: OPTIMA, MINIMA and MICRO receivers.
Extended limits supported
Option for this protocol corresponds to fine frequency tuning. This value is different for each Module and must be accurate otherwise the link will not be stable. Check the Frequency Tuning page to determine it.
CH1 CH2 CH3 CH4 CH5 CH6 CH7 CH8 CH9
Sub_protocol OPT_FW - 0
OPTIMA RXs
Full telemetry available on OpenTX 2.3.3+, still in progress for erskyTx. Lowest the TX_LQI value is best the quality link is, it's a good indicator of how well the module is tuned.
The TX must be close to the RX for the bind negotiation to complete successfully
Sub_protocol OPT_HUB - 1
OPTIMA RXs
Basic telemetry using FrSky Hub on er9x, erskyTX, OpenTX and any radio with FrSky telemetry support with RX voltage, VOLT2 voltage, TX_RSSI and TX_LQI. Lowest the TX_LQI value is best the quality link is, it's a good indicator of how well the module is tuned.
Sub_protocol MINIMA - 2
MINIMA, MICRO and RED receivers. Also used by ARES planes.
https://github.com/pascallange…ols_Details.md#hitec---39
Ich denke also, grundsätzlich geht das was. Da ich kein Hitec-Empfänger besitze, kann ich es aber nicht ausprobieren.
